Inside of starter relay... pics!
Michael211_2000
If you wonder what the inside of the brown OEM starter relay looks like when it starts the "click without starting" trend, here it is! Looks like the electrical contacts have developed some charring over time and it's now unable to pass current thru them when the relay is engaged?
I may try later tonight to clean the charring off with a dremel tool and small wire rotary brush, just for grins. I believe if I can clean this black char off, I can put it back together and it'll work as a spare in the future. Note that there's no signs of oxidation or other corrosion inside, ther is a rubber gasket between the metal back plate and the brown plastic casing, so it's water-tight near as I can tell.
- Michael
Cleaned contacts..
Ok I cleaned up the contacts today... I don't see any reason why it wouldn't work for quite a few more cycles now....
What do you think? There's a miniscule amount of pitting on the switch, but I don't think it'll make any significant difference as far as voltage transmission is concerned.
- Michael
I get that click then nothing often and then it starts like normal. Does this sound like the same relay issue?
Yep. Try this.Open up the hood so you can see the relay.try to start the ski.If it just clicks,take the handle of a screw driver and tap on the side of the relay.....Now give it another try.
Yes, the relay is starting to go bad... it's not making good electrical contact inside. Simplest thing is just to get a new relay and install it. I cleaned my old one up internally and put it back together as a spare for the next time I get the dreaded "Click!".
- Michael
