I took the LRV to the lake last weekend and the Info Center gauge went crazy. The Hi Temp, Low Oil, Maint, lights all came on. The gas gauge was going up and down, L Temp showed 32F at one point and 130F later. At idle, the gauge said it was running at 5800 RPM but there was no way it was really running at that speed. It sounded fine and ran fine but the uncertainty of what was going on caused me to put it back on the trailer.
I started checking sensors and so far they all ohmed out ok to the specifications.
I've worked my way to the info center and I'm starting to wonder if the problem is there. I pulled plug #1 from the MPEM. I first noticed terminal 1-15 had continuity with 1-25. Taking apart the GND and VCC connection between the speedo and info center, I got continuity between GND and 1-15. I also found continuity between 1-15 and the BK-WH on the external air temp sensor.
I there supposed to be continuity between GND, I-15, and the Air sensor? Shop manual doesn't show circuit board info. I'm thinking there is a short on the circuit board inside the gauge but want to confirm my thinking and determine if I need to cut open the gauge to find it. Does anyone have a schematic of the circuit board?
Am I way off? I checked battery connections and they were tight.
