winch_surfer
I have a 97 challenger with a 787.  While replacing the pto flywheel and driveshaft, i've decided to open up and inspect the propulsion system.  Everything seems to be in order until I replaced the impeller cover.  The shaft is very, very tight when the cover is torqued properly.  I noticed the springloaded wedge shape pieces in the cover are to probably tension the shaft, but my shaft will  not turn without allot of force.  The 'wedges' don't seem to slid real easy along each other.
-I doubt the shaft being so tight is normal; Right?
-The thrust washer fell into place. Does it need to be pressed?
-Thrust bearing looks good.
-Will the 'wedges' find a balance after the engine spins the shaft?
Any thoughts or experiences welcome, cause im at a lose.
:cheers:
:cheers:
