Ignition Timing Adjustment for 787
Does the 787 have any adjustment for ignition timing? Looks like it has a fixed trigger.
Yes, it is fixed. The only changes that can be made is through the MPEM programmer. It's only used to retard or advance by a few degrees, mostly by racers. The rotary valve can be considered "timed", since it has to line up at specific degrees agains't the case for open and close.
