Idle speed, acceleration, and top end issue ... SOLVED!!!
mkov608
Wanted to pass this on as lessons learned: I recently started a thread to get some help on a problem I was having. See the link below.
http://www.seadooforum.com/showthread.php?66954-Idle-speed-acceleration-amp-top-end-issue
Well, it turned out to be the j-pipe! I didn't think an exhaust leak could cause such a problem, but also understand Rotax has some secrets to getting horsepower out of engines and the water injection in the exhaust has something to do with it. Thanks Ski-doo (Jeff) for the advice and for the great price on a used pipe.
I've attached before and after RPM range scans. Now I'm hitting that upper band, 7050 RMP, and 61 MPH.
Right, carbon monoxide doesn't burn well and a bilge full of it displaces oxygen needed for combustion, so an exhaust leak into the bilge will definitely create an issue.
You are spot on! I didn't think the exhaust lk was that bad, but for air breathing engines, O2 is much better than CO.
An interesting article here:
http://link.springer.com/article/10.1007/BF03227574#page-1
Looks like the water injection in the exhaust is to meet a US Coast Guard rule that exhaust system components must be below 90 deg C. I thought it was to improve horsepower output.
