frogman112
I own a 2004 GTX 4-Tec. I recently removed the IAC solenoid to clean it and inside the throttle body.
Does the IAC need to be reset with the CANDOO type software or can I just run it as-is?
Also, while I was cleaning it the plunger moved inward towards the solenoid. Is this o.k. or was the stepper motor damaged? I know throttle-by-wire stepper motors can be damaged when the butterfly is forced open by hand. Will the plunger move back out to the correct position when the motor is cranked?
