I have slides on my bunks for my ski's. One set I mounted them on the bunks in the center and the other I mounted them on the outside edge. The set I have in the outside edge cause the bunks to pivot as the load is not in the center.
I have two options.
1). Remove the slides and move them to the center.
2). Buy another set and mount them on the inboard sides on the bunks.
So here is my science question;
If I mount a second set to the inboard side, will the ski be easier or harder to slide?
I understand the friction and pressure concept due to more of the hull touching the slides. BUT,,, slides are designed to "slide".
I do not want to increase the physical amount if strength/load needed to launch or retrieve the ski.
I have two options.
