Hey all, just got my 1996 HX running and in the water. It has a Westcoast head (160psi compression), dual redtop 44's (I believe their 44's but dont know how to verify), twin pipes (not sure what they are from, but they have been modified), MSD box, R&D intake manifold, etc.
I rebuilt the carbs and observed 20psi pop-off pressure on both carbs, and jetting was 95/135 and 107.5/135 with low speed adjustment at 2 & 1/4 turns out and high speed at 1/8 turn out.
The ski runs like garbage. It will idle in the water for about 30 seconds and then die, and requires using the primer to get it started again. It runs great midrange, but bogs out and dies if you attempt anything over half throttle. Sometimes I feel the high jets kick in for a second or two before the bog out. The bogging is worse with the flame arrestors on.
I attempted to open the high speed adjustments to 1 full turn out and it seemed to come alive a little better top end for a second or two before bogging out again.
Im not sure if it isnt getting enough fuel to the carbs, or if the high/low speed adjustments are off, or if it might need a rejetting?
Any suggestions are greatly appreciated, thanks!
