Id like to verify that my oil pumps are working properly. I do not mix my oil with gas. I use the oil pumps.
Today I pulled the 2 small lines coming from the pump off of the rotary valve/motor. I left them connected to the oil pump. I cranked the motor assuming to see a small amount of oil leaving the lines. I did not. I didnt want to pull the pumps off the motor to check them unless I absolutely had to. I did have plenty of oil coming through the oil filters. At this point Im pretty sure I have oil going in but not coming out.
Should I expect to see oil coming out the the small lines when cranking the motor?
If not , how should I check them?
Thanks
Thanks
