is there way to tell if its slipping or if ceramic disk is gone
If you take the intake hose off of the supercharger, with the engine off CAREFULLY see if you can spin the supercharger impeller by hand. Don't cut your hand on the impeller. If you can spin the supercharger impeller, the clutch is slipping and needs a rebuild. Just because it's slipping doesn't mean that the washers broke and fell into the engine.
Once the supercharger is removed you can see if the washers are there or not.
