Well, after over a month of repairs being made to my 97 Challenger, new head cover, replaced gasket on cylinders and had to remove tuned exhaust to repair water leaks.  Then, rebuilt the carbs, breaking a bolt in rotary, so ended up removing exhaust manifold, breaking another bolt, but in the end, drilled out and re-tapped the 8mm and got it all back together, then, took it out today.  It was a bit windy and the seas were about 3 to 5 feet.  I nosed it into the bank for a spell while I adjusted the carbs, etc.....
Then, when I was satisified, I moved away from the bank and at idle, nailed it. It bout jumped out of the water!....man, I could only imagine what those 4-TEC's are like. Hell, my engine is powerful enough!...
I took it out on the other side of the break wall and was only doing about 5 to 6k rpm and was jumping waves, I know a good 6 feet in the air.....man, was it fun. It beat the hell out of me, but it was fun!....
Came in back up river to my house, pulled the plugs.....they read out nice and did compression, got 155 and 158....so, I'm pleased with my work. Patience ( won't tell you about the wrench I threw in the woods, pissed) and a little TLC while working on your stuff, pays off in the end with a smooth running motor!...............:cheers:
Now, who wants to race?...................................
