Help with trailer leaf spring brackets broken
powerslave
This is not on my pwc trailer but my utility trailer. My leaf spring brackets broke off at the trailer frame. They were welded on. Does anyone make bolt on hanger brackets so I wont have to have them welded on?
A picture would help. But,,, get "U-Channel" with longer legs and drill your own holes. Or, take it to any salvage yard, they will slice them off and fabricate others I repaired hundreds for others.
Got to thinking,,, If you get "I-beam, you can get the web to go over the existing rails and be able to bolt left to right instead of "U-channel" where you would have to bolt up and down. Plus, the bolt may have hit the springs.
On an older boat trailer I had the "U" bracket welded to a flat plate. The flat plate had holes drilled in it so I could use u-bolts around the trailer frame, then through the holes in the flat plate.
