Help with Seadoo Islandia Batteries/gas tank vent
leo111
So, I have a trip planned next weekend and got my old friend out of storage last night to give it a look over. I went to hook/connect the batteries back up and noticed that they will still connected (shame on you to the tech who winterized it last fall). They were turned off, but still connected. Everything started just fine. However, the battery alarm sounded....is this just because the batteries may be low and will recharge itself once it is in water and runs for awhile? Or, do I need to worry about them since the outfit that winterized the boat last fall did'nt disconnect the batteries. I did'nt want to run the boat to long being it out of water and so I only let it run about 2-3 minutes. The alarm sounded directly after I started it and I silenced the alarm and it did not sound again, but like I said it was only 2-3 minutes running. It may have sounded again if I had the engine running longer. The batteries are brand new as of last year.
What does everyone think?
Also, towards the end of the season last year when I would fill the gas tank up, it would get full and "spit-up" gas all over the place. I assume there is something lodged/stuck in the gas vent (I'm not sure that is the right term). How and where can I check that to blow that tube out that vents the gas tank? Is it something that I can do myself or do I need to take it somewhere. Someone told me that it is common that maybe a bug or something will get in there and jam it up. Yes, no???
Sounds like the battery may have been low. I would put it on the charger so you aren't surprised this weekend. In regards to your gas filler comment, the condition was new at the end of the season? It was not like that in the past? If so, the vent may be clogged, you. could pull the hose and look.
I would pull the batteries and have them tested some place for free like autozone. It wouldn't be good to get out in the water and stop off some place and not have enough cranking power left to restart. If there that new they might be under warranty. There should be a screen filter on the end of your breather hose for your fuel tank that runs outside your boat check that spot..
