GK5188
Hello,
Quick question on my BN38 I carbs for my 1995 Seadoo GTX. The fuel hose connections are a little different than the pic in the manual. I want to make sure I connect the supply and return to the correct nipples. As well, as connecting the pop off pump to the right supply for the bench test.
I put in some pics for reference. MAG carb to the left.
Which nipple do I connect the Fuel Supply from the fuel selector valve too and which one is the return to tank? Pulse goes to motor and the two nipples facing each other are connected via a fuel hose. I believe.
Just want to make sure I get it right.
Thank you
Thank you
