Hey all,
We took our newly aquired '96 GSX & '01 GS out today, they both ran great but the GS (717 Engine) had a little trouble starting/idling.
It would start for a second and die, it wouln't stay running unless I pushed in the throttle a tiny little bit, then it would fire right up and stay running.
I am thinking possibly that the idle is too low, but I have no way of checking as this machine doesn't have a tach. I am going to add a tach to it, but that may be a winter project.
Also if I floor the throttle from a complete stop the engine hesitates like it's not sure if it want's to go or flood, then it takes off.. Once going it runs great.
I wasn't sure if this was just because the engine's small and just doesn't have the bottom end that my GSX (787) has, or if there is another problem?
The plugs are brand new NGK BR8ES's Gaped at 0.018". I checked the compression and it is between 140PSI-150PSI (I crank the motor over a few times the needle hovers around 140PSI, If I keep cranking or stop then start cranking again the needle jumps up to 150PSI)
I am running atleast some XPS synthetic oil, there was about 1/2 tank of oil already in it when we bought it, I topped it off with XPS Synthetic.
The next issue is with the spitter in the back under the tow ring, on the GS there is no water coming out of it, I blew compessed air threw the line and it wasn't clogged. Obviously the engine is getting cooled as it didn't over heat, but I would like to get the spitter working just as a double-check. Any idea where to start with this?
Also is there any way to check of the Siphon bailer is working? My GSX is bone dry, but the GS always has about 8oz-16oz of water in the hull.
Thanks in advance for the help,
-TheChad
-TheChad
