Help. Taking on water hard and fast!!!!!!
Need4spd
Like 8 to 10 inches of water in it after 20 mins of ride time.
Cant really isolate it. Dont leak inside while running on hose on trailer. 2007 rxt. Been sitting 2. Years. 60 hrs. To run it on trailer hooked to hose the impeller sounds very loud and rattly compaired to the other identical ski i have next to it. Is there a bearing and seal in there. Almost seems to be way worse while running. Any ideas????????
No hoses leaking or unhooked. And yes the plugs arein it.
If i fill it inside on the trailer will the water run out of the impeller shaft if thats the problem??
There is a carbon seal and bearing where the shaft passes through the hull.
Fill the hull with water to a level where it gets above the seal, start the engine and see if it leaks outside of the hull where the shaft passes through. If it doesn't leak right away then run the engine on the hose to keep it cool...
