Cleaning my Rave Valves tonight in my Sea Doo Challenger 96. 787 Rotax. Put on my new gaskets, cleaned everything. Bought this boat used. I noticed on when taking off the rear rave there is a knockout hole on the rave housing and also a knockout hole on the exhaust manifold which the gasket gets sandwiched in the middle. These two holes were not aligned for the rear and forward rave valves. On the forward exhaust manifold the hole is forward and lower. On the rear the hole is rear and lower. The previous owner had the Rave valve with the knockout hole rear and lower on top of the forward exhaust manifold in which the knockout hole was forward and lower. Is this right????? Or should I switch both rave valves and make the knockout holes align between the rave valve and exhaust manifold.
