Hey guys, well after a few good reliable seasons since rebuilding the engine on my 96XP about 3 years ago, she's been giving me all kinds of fits and problems this year. The problems came to a head last week when she left me stranded on the opposite side of my lake and had to get towed back. A little background: about a month ago I was having a different problem where it would die out at times under acceleration, BUT it would always restart, seemed to otherwise start and run fine, and never left me stranded. During that time I rebuilt the carbs thinking that would solve the issue. It did not. I ended up replacing the neg battery cable and that fixed that problem. I noticed when I put the rebuilt carbs back in, the motor would start easily when cold. But when hot it was sometimes a lot more hard to start. Sometimes I would have to hold the throttle wide open for 10+ seconds when restarting. She would start up but barely idle with the throttle wide open for sometimes 10-15 seconds, which I'd never experienced before this carb rebuild. Thought it was strange but the ski otherwise ran great, and sometimes it would start quick when warm. It seemed the longer I would let it sit after shut off, the harder it would get to re-start. This is all just background info to what happened last weekend, riding the ski hard and fast when it randomly just died out and would not restart. A couple times I managed to restart it and would do the same thing I described before: hold throttle wide open while the ski would BARELY stay alive and idle. Again this is holding the throttle wide open and it would barely idle. Eventually wouldn't re-start at all and had to get towed back.
Now the ski will start but won't run in the water for very long without dying. Seems to run on the lift while giving throttle, but won't idle for a long time at all. Compression is good. Changed plugs, verified good battery connection, cut plug wires, etc. One thing I noticed is that I have a see-through Fram fuel filter before the carbs, and there doesn't seem to be a large amount of fuel sitting in there. Of course that's just me and I can't say for sure if that's normal or not. I honestly have no idea where to look now. All the gray fuel lines have been replaced years prior. As I said compression is good. Fuel filter is brand new, and water filter was cleaned out. Fuel selector is bypassed. Any ideas???
