Help... How do I test my coil???
To truly test the coil... you need a dealer tool that is too expensive for most of us.
BUT....
Between the primary, and secondary side, you should see low resistance. (~0.05 ohm) And, the secondary side, to the end of the park wire should be 9 to 15 ohm's (with the cap, add 4.5 ohm)
BUT....
dr honda i would like to check my coil too, i have a 1997 gs should i be looking for the same numbers as you posted in your quote or are the numbers different for my model? Thank You!
