RXP X 300 Boy
Anyone know how to adjust the steering on a 2019+ RXP X 300?? Mine pulls to the right. I've seen a number of videos showing how to adjust other models right off the steering cable under the steering column using the lock not on the cable itself - the recent RXP X models are a bit different and I can't figure out how to get access to the adjustment nut under the steering column. I've adjusted the steering a bit using the lock nut on the end of the steering cable that is affixed to the actual jet nozzle but I suspect there is an "easier" way????
