I have a 2003 4-Tec GTX Supercharged. Running fine last year but on first use this year won't go past 35mph. And running a little rough. The engine sound has changed as well, to a deeper, more growling sound. Probably 150 hours on the engine.
Checked the oil - it was high so removed some (problem remained). Using correct Bombardier oil (mineral, not synthetic).
Using the correct "key".
We tried to spin supercharger impeller by hand - it could not be spun.
As I understand, 2003 model did NOT use ceramic washers, but is still prone to slipping. Is it possible to be slipping under load but not be spun by hand?
At 150 hours, is it due for supercharger overhaul? If it is slipping washers, what else should be replaced?
IF the 2003 does not have ceramic washers that may disintegrate, is light use OK (about 3-5 hours) until I can bring in for service?
Anything else to check?
Any suggestions for repair shop in Brainerd, MN or Minneapolis area?
