I have a 2013 GTX iS 260 Limited. Didn't use it for about 6 months and recently took it out. It idles fine but as you give it some accel, it'll misses a cylinder. It has 65 hours on it and about 50 on the plugs. I changed the plugs, still misfiring. Replaced the 3 coils, still misfiring. We babied it through a tank of gas and filled with fresh 93 octane, still misses. I'm now to the point where I don't wanna guess at parts. I fix cars and it acts like a failing coil but they're new. I took the injectors out and looked closely to see it there's any visible junk in the injector, looks clean. Injectors are expensive so I'm not replacing them unless I have to.
This ran perfect when we put it away last year so something happened from sitting. It sat in a garage covered during the winter. I did not put any treatment in the gas when we stopped using it.
Anybody run into something like this? Is there a way to pull codes without a dedicated tester?
