Hi-
I have a 2003 seadoo gtx 4tec
It starts and runs pretty well, but after 10 minutes or so, produces a p1202 error. If I shut it off and restart it's good for another 10 or 15....
I did some research on this forum and elsewhere, and did some testing:
The TOPS doesn't click when I put the lanyard on, which was the first thing most people mentioned.
Resistance across the Tops sensor was 2.2 ohms.
Voltage at TOPS sensor input wire harness (with or without lanyard in)
Terminal marked "1": 0 (ground presumably)
Termanal marked "2": 12.1 (whether lanyard on or not.)
So, according to a document I found online, the TOPS sensor may be bad, if it's getting 12 volts, but not closing. But it also says it shouldn't be getting 12 volts input until the lanyard is on...
Anyone have any advice or found a better diagnostic thread than I have?
Thanks for any thoughts.
Additional things I noticed..
No oil around front oil pressure sensor (dry around mount, looks newish)
coolant reservoir empty (uh-oh).
oil and water in base of engine compartment- not a lot but it worries me a little.
