Eric Lamberts
Put the boat on the lake for the first time this year. Had changed the oil and filter, charged the battery, put new gas and it ran great. On anchor we noticed that thee back end was almost under water.
Pulled it up on shore and the hull had about a foot of water. Drained it and tried to start--no joy.
Pulled the plugs and turned it over and water squirted out. It almost seemed like it wanted to start.
Now even with the plugs out and a good battery it turns over very slowly. I would like to pull the starter and clean and dry it out.
I removed the two bolts that hold it to the crankcase, and it will wiggle a bit, but it will not come out. I even tried a rope loop around the starter mounting flange and pulling it with a lever. Any ideas?
The leak, by the way was in one of the tubes that hold the OPAS tie rods
Any ideas?? I sure would appreciate and help.
Eric Lamberts Reno NV
