GTX 215 Smokes snd wont start hot?
tbkoppen
Hello,
Im from Sweden and just recently bought my first used Seadoo. But already running in to problems so now im turning to you(the internet pros of seadoos).
My ride:
Seadoo GTX 215 Limited -05
Closed cooling system and supercharged.
98 hours.
My case:
A lot of Gray smoke comes out as soon as it become working temp and i gas more than 2000 rpm. After I turn it off the engine and the startmotor wont even turn the Engine until its cooled down and out of the water.
Its like something gets to hot and then get stuck. I recently change oil, plugs, filter and coolant fluid without any result.
My luck is with you now guys. Anyone have an idea?
Perform a compression check and pull the intercooler. Inspect the intercooler for obstruction and pressure check it for leakage.
When you changed the oil, how much did you put back in? What is the oil level on the dipstick?
