IDoSeaDoo
So I feel that my poor little 587 is cooking itself. The only mods I've done is put on a west coast pipe and add a K&N flame arrestor. I rejetted it with 65low and 152high with pop-off in the mid 30's. I put stock cooling inlet nipples on the exhaust manifold and pulled off the main inlet hose and main outlet hose and made sure both are passing water. I get a full stream from both, so I don't think it's a clog. I plugged the stinger inlet on the pipe and ran the hoses like the stock diagram (to the pee holes in the back). Both spurt water, though one a little stronger than the other.
The plugs look like I'm running rich, though the PTO is a bit darker than the MAG. Weird as it's a single carb system... Anyway, the real problem I'm worried about it that it's overheating. When I take it for a good cruise at 60-100% throttle, upon stopping and opening the hood, the engine will click and tick like an overheated exhaust on a car. One time I even heard the overheat buzzer kick on. I have no clue why this would be as I seem to be getting good water flow through the motor. The exhaust pipe runs cool, but the sides of the engine you can barely touch. The head may be a bit cooler (I think). It never sizzles when I spit on it, so I guess it's not above boiling, but I'm still concerned... I almost feel like I"m running a 657 setup on a 587 cooling system... How can I lower my engine temps? Any suggestions on the plug color differences?
