Hi, having the same problem with two Seadoos and asking for some guidance.
2006 - Seadoo GTI SE
2006 - Seadoo RXT Supercharged
The problems all seemed started when we lost the key to the RXT. I took both skis in and was told "hey, we can make your learner key a full blown key" which I said yes to. Then they said, "want us to do the same on the GTI so both your keys are full blown keys" which I said yes.
Both do the same thing but not always at the same time. They will start up, run for about 5-10 minutes and then bog down and die like they have no fuel. You can start them back up and they will run for a few seconds and eventually die on their own. Eventually they will not even turn over when pressing the start button. I even went and bought new keys and had them both programmed thinking something in the learner key is still making it a learner key. If you let them sit for a few hours they will start back up just fine and do it all over again.
They both have new batteries, spark plugs, changed the gas, and both have low miles. I even sucked all the gas out and changed it with fresh gas. It is odd like it is a security feature or something, b/c they both have the exact same symptoms.
Any ideas or pointers would be appreciated.
Thanks.
Thanks.
