GTI 130 SE - Engine Code P0340
keithpdavis
Premium Member
Premium Member
I have found that the code P0340 is related to the camshaft position sensor - can anyone offer any additional information? The ski will start and run fine most of the time. Occasionally it will kind of hesitate to start. One time it just wouldn't start but that has only happened once. Is there anything I can check other than just replacing the sensor? Any information would be appreciated.
You’re probably going to have better luck getting help in the 4-stroke section... I didn’t even realize the 4tec skis used standard OBDII codes...
If the codes are the same as standard automotive codes, that’s a CPS circuit malfunction. It’s not necessarily a value that’s out of range, but a short or a break in either the sensor itself or somewhere in the wiring harness.
