Hope this is where i post, first ride of year and fresh oil change (have 72 hrs on it also)but it would bog down for approx 2-3 minutes then ran solid in both modes. Starts right away with out any issues.. any ideas?
It would happen each time out that day, after a few minutes it would clear up but at beginning of each session it would act up but i did drain the gas besides anything that could or been left in the engine, but i ran a half tank through on monday also..
That's the procedure in the manual where you pull the spark plugs an injectors, spray in Sea-Doo fogging oil, crank then engine, and reinstall plugs/injectors. This is done to prevent corrosion in the cylinders just in case any nasty water may be in there. The engine will smoke for a bit when you pull it out of storage.
I always put new plugs in at the end of the season (off season storage). For the past 6 years when I pull them out of storage, the skis start right up. I've been able to run the entire riding season on the same plugs.
