Hi Everyone,
First time post here so I want to thank everyone who can help out on this problem.
I have a 96 GSX and over the weekend, the ski got swamped. Everything was wet so I dried it up over night. The next morning I attached the dess key and without any problems it started up and ran without issue.
Yesterday, I went out and tried to start it and all I heard was a buzzing noise from the rear electrical box after some time even that noise disappeared and it would not turn over. I put a voltmeter on the battery and it was showing 12.65v but when I put the charger on it started at 25% which is odd since the day before it was full charged.
After reading all the forums with similar problems and after I bridged the solenoid still nothing. By accident, I was charging the battery, attached the dess key and I heard the two beeps. forgetting I was still charging I bridged the solenoid and it and the engine started. Then I took the charging cables off the battery and nothing. No beeps, it wouldn't even turn over. So I called my local seadoo shop and he said most likely the solenoid needs replacement. I bought a new one and it does the same thing, but when I put the charger on the battery and then attach the key, I get the two beeps, hit the start button and it started.
I just don't know what else could be the issue. All the fuses are good, all contacts are free of corrosion.
I've taken the battery to the shop where I bought it and they tested it. although the specs on the battery are 270CCA, when they put it on the load tester it was showing 451CCA. Mechanic said it was still like new.
Thank you again to all that can help!
Robert
Robert
