grease or oil on carbon seal ? 2018 gti se leaking as new .
motoring
1)after leaking carbon seal change i found the bellows for lack of words shrunk , problem less tension on carbon seal.
2) the stainless suffered from rusting it pitted holding salt water hence spraying salt into entire hull (small droplets )
WOULD CARBON SEAL GET RUINED IF I LUBE IT WITH GREASE OR MORE EASY AND LESS MESSY SPRAY IT WITH ANTI CORROSION SPRAY TO PREVENT THE STAINLESS FROM PITTING
this is a ski that has 25 hours when i noticed it . a basically new ski , a bad design ?
