Grease for IBR module.. Plastic and metal gears/bearings, etc
For those of you that repaired their IBR modules with a new motor, did you grease the gears/screw rod/bearings? There's not a ton in there, but it might make sense to clean the old stuff off (contaminated with burnt motor dust?) and apply some new stuff.. I assume a light coating is fine and I think a "PFTE Compatible lube might be OK".. I have stuff called Super Lube that I think is good for plastic gears and metal as well.
Thoughts? Thanks in advance.
Johnny K
