Then it should be fine... right?
The charging system is very simple... a mag coil, a rectifier/regulator unit, and a battery. If you clean every connection between them... and those 3 parts check out... then it should be working.
OK... so it's not working.
In your first post, you say that they ONLY "get used 2 months out of the year", but now you say they get used all the time. What way is it?? If they get used every day for 2 months... then they sit most of the year.
I just changed a battery in my Polaris. It would crank the engine just fine... but the voltage was dropping below 10.5v and it wasn't enough to fire the CDI. Also... after I charged it... it was 12.5v... but give it a few days, and it was down to 11.7v.
Just because the battery is cranking the engine... doesn't mean that it's good.
Second... just because the stator checked out with a dealer, or shop, doesn't mean that it's working. The regulator is a solid-state device, and when they get hot... they will start to fail. Then, once it cools down... they will work again. At a shop, they are going to give it a quick test, and may not find the problem if it's an intermittent problem.
There is a good chance that your stator is fine. The normal issues are loose/dirty battery connections, or grounds... bad/week batteries, or bad regulators.
