ayrton2727
Had my 1999 challenger 1800 into the shop in the spring because the one engine would not turn over. Make a long story short the crank seal is leaking and allows excess oil into the clinder. The mechanic said as long as I run it every week or so it would not build up. He also said to pinch off the oil line so when the boat was sitting the oil would not run into the cylinder. I have been pinching the line off but I was not doing it low enough so oil was still getting in. My fault. The engine will not turn over again. When I am turning the engine over to get rid of the excess oil how long should I turn it over each time. The mechanic said only very short bursts on the starter. How long should it take and when will I know that all the oil is out. This is only a problem on the port side engine. Engine runs fine other than this problem.
Thanks again for any help.
