IDoSeaDoo
Sooooo I've been running these Novi built carbs with rather oversized jets on my otherwise stock 96 XP. The carbs came with these jets installed, so I figured "Since the carbs have been bored, maybe they need the extra large jets to work properly". The ski started rather hard, but ran well at WOT. Anything below 1/3 throttle, and it sounds ... different, almost like it's firing every other revolution or something. The plugs did show signs of being rich, and I knew more tuning was in order, but knowing that I wasn't doing any permanent damage (i.e. running it lean) I decided to ride it a bit longer before tearing back into the carbs. Well, the last time I rode it, it started to develop this surging at WOT. I took it to mean that this was a sign of a lean condition, and therefore started to open the high needles a bit at a time. After a day of riding, the engine started to die on me, and eventually refused to start back up. Not sure why, probably fouled plugs. I towed it back to the dock but remembered to clamp the coolant inlet hose 4 min or so after we started towing. When we got back to the dock, I took out the plugs and turned it over to find that indeed I did suck some water into the motor. I blew it all out, re-installed the plugs and fired it up. The motor started and ran, but would not achieve high revs. Later that day, I came home and fired it up in the yard and noticed that while it ran, the motor was spurting this black liquid out of the square Magneto electrical connector. At first I thought it was water, but upon closer inspection, I found it to be gasoline... The MAG chamber is filling up with fuel and I am completely at a loss as to how or why... If anyone has ever heard of this, I'd be REEEEAL interested as to what to do. My first plan of action is pulling the flywheel and checking that crank seal, but even if it's bad... I still understand the physics here...
