I am running all new lines and on the vent lines I was checking the check valves. The top check valve check out fine only let's air in( checked by mouth), the hull check valve I couldn't get to do nothing. So I hooked up the vacuum/ pressure gun and finally got it to pop open. Spray brake cleaner and kept flushing it out. Seems fine with the pump but by mouth I can't get it to blow. Should I replace it? Should it be able to operate by mouth pressure?
