Need some troubleshooting advice on a 1995 GTX
ski started bogging down at about half throttle.
I replaced all the fuel lines and pulled the carbs and cleaned the filters. There was a fair amount of crap in there.
Took it for a test run and it ran great for about 10 minutes or so and then died. Wouldn’t run past a fast idle or it would die.
I have two skis are the same year and model, I swapped carbs between skis to see if the issue followed the carbs.
Took it out tonight and same thing. Ran great for about 10 minutes and then died. This time it would not restart at all.The problem stayed with the ski and dod not follow the carbs.
it appears to be fuel delivery But I’m not sure where to start looking. I did already verify that the lines are run correctly and there is no difference between having the fuel select On or Res. I blew and drew on the top check valve and air goes in, does not come out. Checked the filter and its clear.
one more item. While I had things apart I made the fuse fix on the circuit board in the baffle to fix the fuel gauge. I cut about a 3/4” opening to access the fuse but I did not close it back up. It didn’t appear that it was needed since there is a vent right there anyway. Could that be the culprit?
any help is appreciated.
TIA
TIA
