Flush hose adapter not reachable on float dock
Dsmith941
Sorry for the newbie question, but I cant figure out how to connect a hose to the hose adapter (with or without the quick adapter) on my 2004 GTI LE RFI WITHOUT getting in the water behind the floating dock and reaching in to the hose adapter. Is there another access to this line to flush without jumping in the water each time . I would have tio be a contortionist to reach is from on dock since the dock is roughly the size of the SEADOO
Thanks for any advise, Dave
Welcome to the seadoo forum Dave. On my boat lift in my avatar I have a cat walk around the seadoo so I can connect the hose adapter to both engines... It is longer then the hull by about 2 feet so I can kneel on it to connect it.
Karl
here is what I did
Go to lowes or home depot
in the electrical section they sell stiff plastic conduit (gray)
that has some flex -- its about six inches(perfect length)
in the same boxes they sell the threaded end the goes on the conduit and it threads right in the ski -- I then epoxied one of thoses flat zip ties to the well/side and zip tyed it so there is no bouncing around of the conduit -- and the quick disconect threads in the end.
cat -man
Internal....?
I've seen where the flush connection was from the inside engine compartment. All you have to do is determine which hose is the water outlet. Then, cut this hose, put a "T" in it with another section of hose. Put a quick connection coupling on it and there you go, a water flush attachment that is accessible from inside the engine compartment. You'll not only be able to flush but look at the components of your engine while it's running.......:cheers:
