floating ring prob
emtmike
Its been awhile but I am back and as usual I am looking for help. I am trying to replace the wear ring and impeller. I do have the shop manual. What they call a floating ring and it will not move. Does the ring look right in the pic and if so what's my next step?
You really need to add you model and year to you avatar for future problems and questions. Your manual should have a step by step procedure, or maybe it's not seadoo manual like we have here on the seadoo forum. Here is a step by step to help you out.
Here is some information on replacing the wear ring.
For starters....
1.) Remove the three hoses on the inside of the boat. (Attached to the pump) if you do not do this first, you will forget and cause all kinds of problems for yourself!!!
2.) Remove the steering rod, 10mm bolt and nut.
3.) Remove 4 13mm bolts holding nozzle on. with this off you will have a much better view of the wear ring.
4.) Remove 4, 17mm bolts from the pump to hull. Make sure you pull off all the lock washers and washers to ease pulling the pump.
5.) This is the tricky part.... Most shops gob all kinds of silicon on when replacing the pump and so it makes it a pain to pull it away from the hull.
You need to pull the pump away from the hull as straight as possible.
They sell a pump removal tool but I just made my own. Cut a length of 2x4 that I set across the rear of the ski and drilled 2 holes in it. I thread long 13 mm bolts with washers through the top two holes of the pump where the nozzle mounts. This pulls it away nicely with a butterfly impact.
6.) Now you have your pump and impeller in your hands, the next step is to remove the 3 8mm bolts on the cone. Make sure you have something to catch the oil and nose plugs.... This stuff reeks to high heaven...
7.) After cleaning out the oil I place the pump impeller side up in a vice. (grabbing the flat end of the pump shaft in a vice)
8.) Place impeller removal tool in the impeller and grab a 1/2" drive 3/4 socket with a huge breaker bar. Twist it counterclockwise till it pops loose. (May take some pressure. I seriously use a 4 foot pipe on the end of my breaker bar and use a popping motion rather than smooth pressure.)
9.) Now that you have the impeller out take your new wear ring and put it in the freezer.
10.) You have to get the old wear ring out of the pump. (I have found the easiest way is to take a saws all and cut a slit in the wear ring the full length of the pump) Be careful only to cut the wear ring and not the pump.
11.) Take a large standard screwdriver and a hammer and tap the screwdriver gently between the wear ring and the pump all the way around to separate them.
12.) Clean all the white corrosion off the pump where you will be putting the new wear ring
13.) After tackling this task go to the freezer and grab that wear ring. (don’t dilly dally with it) get it to the garage and slide it in the pump. you may have to tap lightly with a rubber mallet. If it doesn’t slide in then you didn’t clean the pump good enough. Repeat steps 9 and 12.....
14.) Reinstall the impeller in the reverse order.
Note: it is very important not to pinch the thrust washer when re-installing the impellor shaft. That’s why it’s a good idea to do it in a vice rather than on the ground sideways.
Once the impellor is tight you should have 1/8 - 1/4 inch play in the shaft back and fourth. if you don’t start over and inspect your thrust washer you probably pinched it..
15) Inspect the rubber o ring and if it is good apply silicon and reinstall the cone. Make sure the allen fill plug is on top.
16) Lower the front of the ski and add oil to the cone. When it is full, take a brake and have a drink. There is air in the cone and when you go back you will see that it is low. Top it off and take another brake... do this until the fluid does not lower again. I often start the ski for a few seconds to make sure oil is all the way worked into the bearings and all the air is out.
17) wipe silicon on the set screw and screw it in (be sure not to run it all the way into the cone. just deeper than flush is fine. let it sit 24 hours to cure the silicon and put the nozzle back on.
18) Use Sea Doo 75w90 GL5 Synthetic Polyester Oil or similar.
Karl
Thanks. I do have the SeaDoo shop manual. I found the floating ring where it is now after getting a rock in the impeller. I had to use a pipe wrench to get it free. My floating ring will not move so maybe all my problems would be taken care of if I was to get that ring further onto the shaft. Not sure if this makes sense or not.
I can now see the problem I think. I removed the Impeller Housing Ass'y and I can see there is a bent fin on the impeller. Not a big bend but still a bend. How much would it have to be bent to make the boat have no speed. RPM's are at 7000 and the boat is just not going like it should.
You don 't need to remove the drive shaft to replace wear ring or remove impeller. Also any bend in an impeller will have an effect .
It might not be that just the impeller is bent, but it must have done damage to the wear ring too. The combination of the 2 damaged items is causing your problem...
Karl
I will be ordering a new ring and one of there reworked impellers from SBT in the AM. Thanks for your help. I will let you know how it turns out.
