gsxgtxman
Alright! So my brother n law takes my GSX for a ride! From the campsite I see he has swam it up to the bank upside down, and flips the thing over, right side up! I haul a$$ to bank and immediately pull the seat! Water was up to the pipe! I immediately pull the drain plugs and release all the water from the hull! I pull the plugs and remove the water from the engine! Tried to fire it up , wouldn't crank! Got it home finally got it to run!
I've emptied the gas tank. I drained and refilled oil! Pulled the carbs,cleaned. New spark plugs! The thing runs like crap! Will not break 4000 rpm. 150 psi on both cylinders!
Any suggestions?
Any suggestions?
