jonniex5
With all the discussion on battery's needing to be disconnected to charge so the MPEM doesn't get fried.
I added a battery disconnect I found on line good for 200 amps, the knob if turned to "out" you can take the knob out to prevent anyone from starting the ski.
If I need to charge the battery I turn the disconnect off and put the charger to the battery.
The accessory wire you see goes to a automatic bilge pump and is fused at the battery.
All wires were loomed and Tie-w
rapped after I took the pictures.
Hope this may help someone.
Regards
rapped after I took the pictures.Hope this may help someone.
Regards
