OK This is my first pwc and its been nothing but trouble and only been out twice for no longer than 10 minuets
Firstly it had a host of sensors down all have now been replaced and shows no fault codes. Here is what happened took it to the local lake on Sunday and had a blast for ten or so minuets, Went into the bank side to collect my kids I tried to get off to assist them in mounting but all the weight on one side tipped it over on its left side (if you were sitting on the craft) once back on its hull and restarted it had sucked up a few pebbles from the bottom of the lake. I took it out of the water and removed said pebbles, it now appeared to be running fine. After launching again it started to rev up to 5000 rpm then die even though the rev counter flew up to 8000 it just refused to pull through the water. Now its home and running on the hose I have replaced the plugs and fuel filter and now if you blast the throttle from tick over to full it revs nicely and bounces of the rev limiter like it should do, But if you rev it slowly it gets to 5000 again and bogs down almost like its starved of air or fuel? There is no one local who I can take this to so all help is appreciated
cheers
P.s Its a 2003 gtx 1500 155
cheers
