2001GTXseadooRFI
So last weekend the exhaust resonator on my ski failed and I took on water and sunk. got the ski running again, flushed everything out as I should. Later on I found out why the ski took on water. So I know that it took on water because the seam failure and an additional hole the size of a quater in the elbow of the resonator formed. But my question is why? Is this something that can typically happen with an older machine? What could have caused this? i would think this was a perfect reason as why the exhaust should not be made of plastic. the spark plugs loaded up coming off the dock. So I stopped in shallow water area, changed the plugs. Got it up and running again. Then I started making a few quick passes to clear it out. I heard a pop, the engine died. exhaust smoke started comming up from the hood. I couldnt keep it running after that. I then heard water rushing in by the battery area and the rest was history. The best I can figure is that the exhaust system might have filled up with unburnt fuel/fumes as the ski was only running on one cylinder for a few minutes. Then when I got it going with fresh plugs and the hot exhaust mixed with the unburnt fuel, boom blown out exhaust. Any thoughts?
