68ragtop
Tearing into the 2008 RXPx I picked this weekend. Upon removing the SC I found the Exhaust temp sensor had melted & was laying on the hull. Also the air intake tube was melted some to the water box. Not sure if the cooling system was plugged at some point, or it was run too long on the trailer without a hose?
I would think the ski would trip a code if it don't see a rise in temp? There were no codes with a short startup on the trailer. (all I have been able to do so far) I will flush out the cooling lines to make sure they are not abstracted as I can see some sand inside the water inlet hose, just inside the (currently removed) pump. Can this be done on a 4-tec without the engine running, or do I have to have to have it running to prevent water from back washing or spraying into the engine?
HHhmmmmmmm
HHhmmmmmmm
