O OzTEXS Member Jan 22, 2018 #1 Hi I recently returned from a trip that included beaching my seadoo speedster 200 for several hrs Upon Return to shore I noticed once I opened the drain plug an unusual amount of water with a ting of oil gushed out Would there be a specific reason for this ??
kernal Active Member Jan 22, 2018 #2 Check your carbon seals and bellows. best way is stick a gopro camera, or the like in there and record while your running to see if it's leaking.
O OzTEXS Member Jan 22, 2018 #3 kernal said: Check your carbon seals and bellows. best way is stick a gopro camera, or the like in there and record while your running to see if it's leaking. Click to expand... Can this be a serious issue ?
JPass Well-Known Member Jan 22, 2018 #4 OzTEXS said: Can this be a serious issue ? Click to expand... Yes it can if the bellows were to rupture. It's what keeps the water out where the drive shaft passes from the outside to the inside of the hull.
kernal Active Member Jan 24, 2018 #5 if it started after you beached, I'd slide under it on the trailer and inspect the bottom and pumps as well, just for piece of mind.
timeman Active Member Jan 27, 2018 #6 I used to get water in the ski locker...I replaced my carbon seal and siliconed (top / bottom) my rub rail now I get zero water.
