millertime23
The driver's side rear engine mount and the front engine mount only have 1 shim installed each.
In order to get the shaft alignment tool to even be close to lining up, I will have to use WAY more shims on the passenger side rear engine mount than the manual says is the max. It looks like I'd have to use about 4 or 5 of the thicker shims (maybe even more). Will this create a problem?
Also, the entire engine seems like it needs to be rotated clockwise to be straight with the alignment tool, you can kinda see this in the pics. I don't even know if "rotating" the engine clockwise is possible.
The alignment tool shaft seems to be coming through the hull way off to the left, it's not very centered in the opening. It's pretty clear in the second pic.
Could I have a problem on the mounting surface for the jet pump? Can the jet pump mount be shimmed? Really need some help from the pros on here!
