Hi,
I've recently purchased a 98 GSX limited from a private seller and after fixing a myriad of other problems I wasn't told of I've come to one which I need some help and advice with. I think it's best if I tell you what's happened and then give my take on the situation.
I've had this ski for only a couple of weeks (First jet-ski I've ever owned too) and previous owner was gracious enough to give me a new battery to put in as the old one was well and truely dying. He gave me a dry, vented motorcycle battery which I filled with acid, charged up and put it in and finally got her started after fixing other non-related problems. It has been working fine for the couple times i've taken it out until yesterday.
Went out for 2 runs, all was fine and running good. About 2 hours after second run when to start it to retrieve it and the entire electrical system was dead, couldn't even get the dash to come alive with the DESS cap on. It was late so left in the water at my mates and come to today to try and fix it. Take out the battery, the acid level was down but not alot, however it only had .14 Volts and wouldn't accept a charge, so the new battery was well and truly buggered. Got a new sealed lead acid, charged up and put it in, after alot of touble starting finally got it and took of for a run. After about 200m I open the throttle and it's still only at a fast idle, no acceleration at all and the engine is struggling. Additionally the dash is flashing on/off and doing the thing where all the LCD segments light up. As soon as I release the throttle it died. After this the entire electrical system was dead again, but battery still had 12.14 V in it.
Finally got it to the ramp and home and checked the fuses. Found both of the charging circuit protection fuses (1 in the High Volt box at the back and 1 on the MPEM in the front) which are meant to be 15A had 20A fuses in them. The fuse in the High Volt box, the plastic melted and fuse blown and the one on the MPEM was about to blow and had started melting. Replaced with 15A fuses and was able to start and run the engine out of water without hassle. However did notice that whilst engine was running the "12 V Low" warning was constantly on and dissappeared as soon as the engine stopped.
So from what I can tell there's a problem with possibly either the magneto or the charge regulator and this has caused an overamp and cooked the old battery. However at the same time I'm also thinking the magneto/charging system has no output and the 12V low warning is on because it's driving a spark from the battery only and this would account for the rough running and dying of the dash. What's your take on it? Any advice would be appreciated
Cheers, and sorry for the length of the post.
