2000 Islandia suddenly stopped running. Both the Fuel primer pump and the Vapor Separator fuel pump no longer pump with the key on. Both run if supplied a ground. Ran the pump tests as well a validated continuity to ECM via pin 2, which suggest the ECM has finally let go. 2 questions:
1. Are there any other tests I should run before assuming the ECM is bad?
2. Does anyone know of a shop that repair and ECM or if one is available aftermarket?
Thanks,
Scott
Thanks,
Scott
