I've been working on a 1996 XP restoration which has its own thread. I fine tune small items after it gets on the water so it will achieve top performance. This one had weird issues that I resolved. It was very interesting. After my last.... "Oh, wow I found some cool stuff that would definitely affect performance !!! It''s gonna be great now !!" episodes... I mean, I even got the fuel gauge working. It was cherry and ready. This is gonna be good.... Here goes.
Took the ski out ran great. Wide open throttle 55 sometimes 56mph..... speed dropped off wouldn't take the fuel on top end but i could ride and have fun on the ski. 45mph... no issues.. Didn't kill if I backed off the throttle. Plugs.... brown... not lean. Rebuild another set of carbs (old carbs had some issues). Same problem. Fed system from the reserve line on the fuel baffle direct to carb, same problem. Replaced the ignition coil, same problem. Went through the rave valves as well. Ski would quit in the same place after running Wide open throttle for about 1/2 mile. I mean within 50 yards. I checked and checked and checked. Even wondered if something electrical was breaking down.
I was planning on running an alternate fuel source when I thought I might have pinched the fuel tubes on the baffle by tightening the hoses too much. So I pulled the baffle and the tubes were not restricted very much. So..... I looked at the baffle I installed. It had been repaired and did not have a bottom screen. Being handy with such things i confiscated my wife's coffee filter for the screen and melted it on the bottom of the baffle. So now we're getting somewhere. It took a bit for the baffle to drain the fuel out and it keep dripping. Hmmmmm.... I decided to pour some fuel through the screen and into the baffle (upside down). Hmmmm..... that didn't go as expected. Hmmmm.... REVELATION time.
So...... that's why the fuel gauge would read "FULL" full then the red light would come on showing "LOW Fuel". The baffle was not refilling fast enough for the fuel used at high power settings. It was getting drained. The information was right there. LOL.... I thought this was worth reposting.
I'm pretty anal and will NOT go filter-less on a system and this is the result. I did try to find a proper filter screen and went to a few local hardware stores and even a repair shop. I'd just get a dumb look. At present I am working on the proper Micron screen material so I can put the right stuff on there. The baffle is actually a pre-filter so the microns can be a bit larger. at present I"m looking at between 10 and 30 micron stainless mesh.
In my defense, the specific gravity of water and fuel are different so I figured if the coffee filter would allow WATER though that fuel would not be a problem. I like it when I outsmart myself. Ick !!
No test ride yet but now I can try to get that 57mph out of it. I hit 56.
Touchdowns Everyone. LOL
