Bigdady536
I have a 1997 seadoo speedster that only one motor will crank over. When I push the start button to start the driver side motor there is just a clicking noise. I checked the selinoid and I crossed the two bolts and no spark. I cross the other side for the other motor and got spark. I check all the fuses and one was blown and replaced it and it did not fix the problem. I swith the silinoids around to see if it was bad and the one that worked didn't work and the other did so the selinoids are good. It does not seem like the one silinoids is getting power. I don't know what it could be. If anyone has any on what I should check to begin eliminating possible problems would be great. The starter does notseem to be getting any power to crank the motor the starter does not make any noise at all so I think the starter is fine just no juice getting to it. Also the battery has plenty of power because it cranks the port side motor just fine. Please give me any advice thanks mike
